Thread: Bleach Calculator
    Default Re: Bleach Calculator
    When I click on the link or copy and paste the link, it opens a new window and I get the following message:
    Server not found
    Firefox can't find the server at richardfalk.home.comcast.net.
    * Check the address for typing errors such as
    ww.example.com instead of
    www.example.com
    * If you are unable to load any pages, check your computer's network
    connection.
    * If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.
    If you can email it to me, I would be truly greatful. My email is [email protected].
    Thanks so much!
    ~Sherry
    drband's Avatar
    drband is offline Lifetime Member Thread Analyst drband 0
    Gainesville, GA
    sent it. Note instructions in the email for accessing the file. Hope this works for you. An alternate calculator is on the troublefreepool.com site. This calculator runs in your browser, so should run in firefox or IE. Links follow: (paste each one into your browser address bar to access it)
    new bleachcalc link :
    http://troublefreepool.com/files/BleachCalc262.exe
    poolcalc:
    http://www.minbar.com/pool_calc.html
    The poolcalc webpage can be saved to your desktop so it can be used off-line if needed. It's a really user friendly way to show all of your test results and chemical needs on the same page.
    Bleachcalc is a great tool, too and is really good at giving you the data for one chemical at a time. After you've been testing for a while, either tool will do the job.
    drband
