Thread: Sources of Metal
    Jul 2006
    Default Sources of Metal
    I've a recurring stain problem in my fiberglass IG pool. Tried all of the recommended treatments - work fine but within a week the stain is returning even with above recommended doses of sequesterant. I'm currently using Pro Team's Metal Magic as it will remove the stain without going thru the ascorbic acid procedure (which I've done 3 times).
    Water supply is city water from sourced from the Great Lakes so the metal isn't coming entering with fill.
    I'm wondering, the heater is 10 yo. - Is it possible that the heat exchanger is corroding and could be the source of the metals? Putting metal into the water at a faster rate than I can remove it or keep it suspended?
    Indiana.
    Default Re: Sources of Metal
    Quote Originally Posted by MrSparkle View Post
    Heat exchangers are a pretty common source of metal in the pool. Other possibilities are algaecides, mineral systems like the Nature2 or some other "alternative" sanitizers that contain copper.
    Lafayette, La
    I was having the same staining problem with my fiberglas pool this year. I found that keeping my pH between 7.2 and 7.5 and my chlorine at about 3ppm kept the stain away. If my pH creeps up the stain returns- Can't explain why.
    mbar's Avatar
    Ashland, PA
    grangerhj is right, you must keep your ph on the low side in a fiberglass pool. Fiberglass tends to stain very easily. Metals can get in your water in so many ways. Even calcium is a metal. If you have been using Proteams metal magic, you probably have a lot of sequestereing agent in the water, so taking your ph down should eliminate the stains. Also keep your alkalinity about 80, and your calcium low - about 150. Keep your chlorine on the low side of your "best guess chart" and use bleach instead of pucks or calhypo.
    Northeast PA
    Michigan
    I learned our heater was the source of our severe staining. At one point, our fiberglass steps were dark gold! Try using Natural Chemistry's Metal Free. One weekly dose of 10 ounces keeps the stain from occuring (25,000 gallon pool) Works perfect for us.
    Why BBB? Because money can't buy happiness, but saving it sure can!
  1. Cost Comparison of Chlorine Sources
    By chem geek in forum The China Shop
    Last Post: 06-26-2013, 03:10 PM
  2. Sources for pool coping and tile
    By GaryDG in forum In-Ground Pool Construction and Repair
    Last Post: 07-29-2011, 09:50 PM
  3. Sources of Calcium
    By nomar116 in forum Dealing with Alkalinity and Calcium
    Last Post: 12-16-2010, 10:09 AM
  4. Using other sources for pool equipment
    By NomenNescio in forum Pool Equipment & Operations
    Last Post: 08-13-2006, 03:08 PM
  5. Ascorbic Acid SOURCES
    By johnsislandpool in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-27-2006, 08:44 PM
