Re: Pump and filter combo.
from what I've learned here so far is that a smaller hp rated pump is better to use, as it does not blow debris through the filter and back into the pool. Hayward is what was suggested to me and others as a good replacement pump. there are 3/4, 1, 1.5, and 2hp pumps. Oh, and 2 speed, is better that the one speed. Hopes this helps.
