Results 1 to 10 of 11
Thread: We have a 23.5'x13.5' AG pool! Now how to fit top rails?
    Kansas
    Default Re: We have a 23.5'x13.5' AG pool! Now how to fit top rails?
    Ours came with metal top & bottom rails/plates and resin top seats. We bought the Ultima.
    You could call them & inform them of the mistake & how you remedied it. But if you brought it to their attention it could prevent it from happening to someone else.
    Hope all is well,
    ~Hoffmans
    zephans is offline Registered+ Thread Analyst zephans 0
    Bothell, WA
    I'll definitely talk with them. I have one place in my notes that mentions metal top rail so I need to track down when and where I made that remark. The product page clearly states resin.
    UPDATE: I think I found a different root cause for my metal rails not lining up properly. Turns out two of my towers (the two closest to my yard) are slightly tilted at the top. The bottoms are 42" center-to-center but the tops are about 1.5" off plumb. This explains why two of my rail tops are 1.5" too short to connect these two towers AND my rail tops get scrunched (too long) only on this one side of the pool.
    This would be trivial to fix if the water wasn't filled up yet. However the pressure from the water has the wall pushing so hard that I can't budge the column enough to connect the top rail between center tower and this outer tower.
    OPTION A: Temporary buttress: Lay one 2x4 vertical against side I want to nudge tower toward, then use another 2x4 angled against nearby dirt bank to make a very temporary makeshift buttress. If I can push the wall far enough to releive the tower I can nudge the tower then carefully release pressure from temporary buttress.
    I tried this once but the bank gave way with very little budge in the wall. Man, that's a lot of pressure! I'll put on my engineer cap and think of a way to shore up the buttress base then try again. I am worried about making deep scratches if I push the tower top while side still has some weight against it.
    OPTION B: drain water half way, adjust towers, refill. I'd really REALLY hate to dump 4,600 gallons of perfectly good water. I have no idea what our water bill will be for this month (since we just filled the pool) but I don't want to increase it by another 4,600. HEY, I have my old 12' easy-set "doughnut pool" I could set up just for this job. I might have a place level enough, then use the pump + pool vacuum to pull out the water and pull it back in when I'm done. Liner has only been filled for about 3 weeks so it shouldn't shrink any (and I won't drain down too far). Still this sounds like a ton of work for my silly 1.5" off-plumb mistake .
    Please post if you have any better ideas (or confirmation/cautions for either option above). I'm working more on plan B as soon as I find a spare 30min and the kids and neighbors aren't all playing in the fully operational (if not fully finished) pool.
    Thanks! -ZephanS
    AG BF 13.5'x23.5'x54" (wups) Diamond Star (Wil-bar) purchased 5/30/2007 from sunenterprises.com. 2hp pump + 150lb sand filter (both WaterWay combo) using 75lbs zeobrite + SWG.
    Dug and built ourselves in ~30hrs by ~7/4 thanks to PF (esp. hrdennis,nwmnmom,matt4x4,Waste,CarlD, &others). ~$5,500 total cost.
    Zephans,
    Option B sounds like your best bet, once you have the water transfered to the other pool, using method A to move the column plumb will be easy.
    While you do this, the swimming will not be interrupted since everyone can use your temporary pool that you set up just for them
    Use option A to perform the fix if needed - although I believe at this time you should just be able to move the column by hand.
    Refill and toss the swimmers from the little pool into the big pool - they won't even notice!
    I agree with Matt. A small amount off plumb can lead to bigger problems down the road when everything settles and shifts, especially after the first winter/spring cycle. You may not get a freeze, but I'm betting you get a rainy/wet season where your ground conditions are much different than right now. Better safe than sorry.
    Bothell, WA
    OK, I got some 1 1/4" fuel hose to hook up to my waste port and I'll do the deed tomorrow.
    Yes, we do get a substantial rainy season around Seattle . Funny enough, we're even having record rainfall over the last couple days. (Usually July is relatively dry and in 70's to 80's in Western Washington.)
    PS: Neighbor kids now love coming over. However they scream each time they get in our unheated ~65-70 degree pool . For now I tell them to swim two laps with crawl stroke (repeat as necessary). Once I solve this top rail connection issue (and underlying support tower plumb issue) I'll start hooking up the 4'x20' solar panel currently sitting in my garage unopened. My wife and I would also like to start using the pool (without wetsuits ).
    Thanks! -ZephanS
    Well we are all anxious to see some pictures that include the family INSIDE the pool enjoying all the benefits of your hard work!!!
    Bothell, WA
    Cool Re: We have a 23.5'x13.5' AG pool! Now how to fit top rails?
    UPDATE: Mission accomplished!
    We drained ~2,300 gallons to our 12' doughnut pool, then wasted maybe 300 gallons to the yard. I was then able to push the side wall enough to adjust the side towers. That got the side sections of top seat rails to connect. We then pumped all 2,300 gallons back into the pool and refilled the little we had to waste. Went like a charm!
    Second problem was curved rails. Here we needed to actually compress them more than adjustable slots allowed. Only one end of the pool needed this treatment. The other end barely squeaked in with existing adjustable slots... I guess I took out about 2" more curve from one end than the other. SOLUTION: I drilled a hole just past the slot on one side of each top seat rail along this end. The collective effect was just enough to work out. Yeah!!! Too bad it took me 3+ weeks to get to it.
    Rail caps are installed and the pool looks 100% finished! (Just don't look for the final #10 screws to attach bottom of each rail cap... or the landscaping for that matter. I'm still working on these and other cosmetic touches )
    Our kids and all the neighborhood kids are happy as clams (and a bit clammy after swimming in 65-70 degree F water).
    Alright nwmnmom, you asked nicely for pictures and were very patient... so here you go...
    Next mission: Get hardware to install solar panels so kids can stop playing "Penguins and icebergs"... but that will be a separate thread .
    Thanks! -ZephanS
