Thread: Green algae? Mustard algae?
    Default Re: Green algae? Mustard algae?
    I have a Hayward DE filter with a Hayward Super Pump. I also have a Rheem electric heat pump for heating the pool. Given all this equipment, can I pour bleach right into the skimmers, or do I need to remove the solar cover and distribute bleach into the water every time I need to add it? I'm worried that having the bleach circulate through the filter, pump and heater in such high concentrations will damage this equipment somehow. The heater has a copper coil, not titanium, unfortunately. Perhaps even more importantly, the bleach will be going through my Hayward Chlorinator with 3" pucks in it. Will this cause some sort of chemical mismatch? I know there are some types of chlorine you can't put into the chlorinator.
    As for the solar cover, it's a necessity as I pay the highest electric rates in the country (0.19 KwH !!) , and it saves me over $1000.00 per season in electric to use it. It is, however, a major hassle to use, as I have an unusually large "L" shaped pool and the cover has to come off and on manually in three separate pieces. Any info on the perils, if any, of adding the bleach right through the skimmer would be appreciated. Thanks!
    salinda is offline Lifetime Member Weir Watcher salinda 0
    San Jose, CA
    Well you don't have the highest rates. Ours are about 0.35/kwh in Northern California if you hit over 300% of baseline. The baseline is set so low that you would have to live in a cave to meet it. It is not adjusted for large family or anything. I have energy star appliances. My new pump keeps me below the rate, but just barely so I ONLY pay 0.32/kwh!
    Do you have an electric heater or a water well with a pump? Is that how you are saving on electricity? I have a gas heater (along with my solar heater) and municipal water so I can't see where a cover would save me anything but on my water bill. It would also allow us to swim much longer around here, but my pool is a large, odd shape so it would be cumbersome to use.
    I have brownish algae spots every now and then in a dead area of my pool, but brushing allows the saltwater chlorinator to keep it at bay.
    Salinda
    NW Oregon
    From what I have learned on this forum, it is safe to add bleach through the skimmer as long as you don't have a trichlor chlorine injector in use. The bleach makes a short trip through the filter and heater and is quickly followed and diluted by pool water. As long as the pump is running for a few hours after you add bleach, it shouldn't be a problem.
    34 X 22/15 inground vinyl w/ Hayward equipment
