Thread: Side Discharge pump
    Question Side Discharge pump
    I just purchased a new pump for my AG pool. My pump that I have not is a top discharge and this one is a side discharge. The reason I bought this is because I got it for about $150 on eBay, brand new in the box, 2 HP two-speed Waterway/A.O. Smith pump. I only plan on using it on low and it will be enough for my 24-foot pool. My question is, my husband seems to think he can unscrew something and change it to a top discharge so he won't have to rig the plumbing that we already have (flexible pipes). I don't want him messing with my bargain of a pump. Any thoughts? Thanks, Penny
    Default Re: Side Discharge pump
    Most above ground pumps can be switched between side and top discharge but the way that they need to be changed varies by brand and model. You can possibly find the manual for your Waterway pump here on the Waterway website. It should tell you what you need to know.
  1. Suction side leak . . . Found in Pump Drain Plugs
    By TomC in forum Pool Equipment & Operations
    Last Post: 06-15-2012, 05:26 PM
  2. Cloudy pump discharge
    By ChrisB in forum Pool Equipment & Operations
    Last Post: 05-26-2012, 12:43 AM
  3. Possible Suction side leak - booster pump
    By izzicat in forum Pool Equipment & Operations
    Last Post: 06-07-2011, 02:16 PM
  4. Mars HP pressure side cleaner and NO booster pump
    By waterbear in forum Pool Cleaning: Manual or Automatic
    Last Post: 04-21-2007, 08:50 PM
  5. suction-side cleaner or pressure-side
    By JShilling in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-08-2006, 08:58 PM
