Re: algae or sand ?
Could be either one, need more information. Is it gritty or slimy to feel? When you rub it between your fingers does it smear? Have you had a recent algae bloom? What is your CYA level and your chlorine level? Is it on the sides or just the bottom of the pool? Do you have a sand filter? Is there any other way that sand or dirt would have been introduced into the pool? Have you tried shocking the pool to see if it makes any difference?
