Re: Confused about CYA and Chlorine levels.
The chlorine and CYA chart is labelled "Ben's Best Guess Chart". Once you have algae, your chlorine will be consumed very quickly. Even going four hours between tests will show a big drop in chlorine. You need to stay after it, going no more than 8 hours between chlorine tests and additions. It will be difficult without a good test kit, but you can use the dilution method to increase your range.
