Re: difference in Taylor chlorine tests
Also, you don't need two scoops of FAS-DPD powder. You just need enough to turn the water dark pink--like rose wine. Adding more doesn't change the reading you get, it just wastes the powder. But if it doesn't turn that dark pink unless you add two scoops, then, of course, use the two scoops (unless you have no chlorine, in which case it won't change color at all).
Thanks for the info. That's good info that the directions don't give. Denise
