Thread: Alk
    Scottsdale, Arizona
    Default Alk
    My Alk is running 140 and I am having to add acid more than I use too , should I bother with the aeration to lower it or live with it ?
    da numbers :
    FC 15
    pH 7.8
    CAL 480
    ALK 140
    CYA 20
    Salt 3700
    FC is high because I'm shocking due to a couple spots of algae on the steps.
    CYA surprises me since I added some at the end of last summer. I though it was higher. Since the SWCG specs call for 50-80, I'm going to pick up about 6 lbs and shoot for a reading of 60.
    Any advise ?
    14'x31' kidney 21K gal IG plaster pool; SWCG (Saline Generating System's SGS Breeze); Pentair FNS Plus 48 DE DE filter; Whisperflow 1 HP pump; 8 hours hrs; kit purchased from Ben; utility water; summer: none; winter: none; PF:5.7
    mbar's Avatar
    mbar is offline Lifetime Member Whizbang Spinner mbar 3 stars mbar 3 stars mbar 3 stars mbar 3 stars
    Ashland, PA
    Default Re: Alk
    Your calcium, ph and alkalinity are all high, although your ph maybe is showing high because of the high chlorine. Has your ph been that high, or just this test? You can lower your ph to 7, aerate (turn your return jets up to bubble the water) the water to bring the alk down. Everytime the ph get up to 7.5, take it back down to continue the process. Acid will not take the alkalinity down on it's own. It is the aeration process that gasses off the alkalinity only when the ph is under 7.6. You can also drain some of your water that will take the calcium down too. You should have your calcium between 200 - 400, alkalinity should be between 80-120. I'm not sure where you live, but I lose cya over the winter here in PA.
    Northeast PA
    16'x32' kidney 16K gal IG fiberglass pool; Bleach; Hayward 200lb sand filter; Hayward pump; 24hrs; Pf200; well; summer: none; winter: mesh; ; PF:7.5
