Results 1 to 10 of 15
Thread: For those of you with sand blowing back into the pool....
    Default For those of you with sand blowing back into the pool....
    I've learned a great deal in the past week about what can/will go wrong with a sand filter. Many, many times on this forum people have complained about sand blowing back into the pool, and many times we (I) have advised people to go look for a broken or cracked lateral. I will in the future recommend that while looking for a crack in the lateral, that you also check the space between the lateral and the hub they fit onto. There shouldn't be one.
    I have just had extensive work and time put into my filter because when it was first installed 6 seasons ago, it was apparently "pieced together" by the installer, and installed in such a way that there was tension on the hub containing the laterals. This caused three of the laterals to have enough space between them and the hub to allow sand through and up into the pipe carrying the return water. The sand got into the joint of this pipe where it connects to the hub, and proceeded to sand down the inside pipe, loosening the fit between the two, allowing progressively more and more sand to be blown into the return water and eventually into my pool.
    The only symptom I had was a little sand appearing in the pool the first two seasons, and then becoming progressively more and more until this season, when if I turn the pump off and let it settle, I actually have about 1 - 1/2 inches of sand around the edges of the deep end. Once we figured out what the problem was and correctly installed a new hub and siliconed the pipe back into the hub, the problem is completely resolved. We vac'd it to waste, left the filter running for 2 days straight after that, and for the first time since the pool was built, have NO sand in it.
    So--long story short--if you're having recurring problems with sand and don't find a crack or break in your lateral, carefully inspect where the laterals fit onto the hub. That may very well be your problem.
    ScottS is offline Registered+ Thread Analyst ScottS 0
    Covington, LA.
    Default Re: For those of you with sand blowing back into the pool....
    Great post, thanks!
    This will be another thing that I can check as well when I break the filter down.
    Now when you refer to the "hub" is that the point where all of the laterals screw into the PVC which connects to the multiport valve (this part rests on the bottom of the tank)? If so where was the space created?
    Sorry if the questions sound silly but I am trying to picture exactly where the tension was and what happened.
    Thanks Janet!
    Yes, it's the part that the laterals screw into, that sits on the bottom...when the laterals are seated in place, there shouldn't be any space between the laterals and the part they're connected to. (Sorry that may not be the best description, but I didn't think to take pics while we had it apart.) Mine were seated in as far as they would go, but it appeared as if they were not screwed all the way in, creating about 1/2" of space between the end of the lateral and the hub, on three of the laterals. Further, The hub has an opening underneath it where the filtered water goes back up into the center into a pipe, and that pipe connects to an L-shaped piece of pipe that goes back out to the multiport valve. It is the connectioin between this L-shaped pipe and the hub pipe that the sand got in between and literally sanded down the inside pipe at the joint, creating space between the two pipes for more sand to enter the return stream.
    Does that help?
    Quote Originally Posted by chuck9997 View Post
    I have the same problem.. with sand.. in a 24foot AG.. I am clueless about tearing down the filter.. and what to look for inside. Are there any pics and/or instructions for filter repairs and maintenance. Is it a BIG job?
    It's really not a big job....we opened the drain plug at the bottom to let the water drain, bled off the air while slowly removing the nut on top and taking the top off....then it's just a matter of scooping sand out of the filter. It would take much less time with a wet/dry vac, but it took me about 45 minutes to shovel 300 lbs of sand into the bucket of my tractor and go dump it. When you get to the bottom and can see the laterals, the whole assembly lifts out. Not a big deal, just kind of messy.
    Tennessee.
    I've been thinking about this.. and,.. at least for the first time,.. I think I will do as Andy Taylor told Aunt Bee.. I'll: "CALL THE MAN" .. and watch him.
    Swimming pool.. or camper? Swimming pool.. or camper? ...what the heck.. buy both.
    Carterville,IL
    This is my first FULL season with the new 30' AG. I am seeing some sand along the seams quite often.Vacuumed yest. and wa la...today....more sand. Probably only a 1/2 a cup full. Not much, but annoying. A friend of mine told me not to back wash as often, as it makes the sand "more sticky". This didn't sound too intelligent, AND I don't back wash every single week. My pool doesn't have many people in it often, and at that not many kids. I backwash about once every 3 weeks. I know I know....but it's looked good since day 1.
    Anyway, I don't assume I have a cracked lateral, and probably have a lateral head with some "space". The filter was already assembled when they installed, so I guess I have to wait till I close the pool in order to "check this". Sounds like a good plan, but I guess I can deal with the sand till mid sept when we close.......
    I just can't imagine how to do all that with the pool still open? Plus, I would rather try and wait and just kill two birds w/ one stone and change the sand next season. I know that with Chlorine, they say every 3-5 years, but whats $30 or so to ensure sparkling water w/ fresh sand eh?
    Anyway.....keep this post going. Very educational....and with all my jibberish, can someone post me back?
    30' Esther Williams Classic Granite
    Installed july 2006
    Carterville,IL
    An idea would be for someone to go to say the website of a filter, screen shoot the diagram of the lateral heads, and describe based on what the diagram shows. Just a thought.
    Installed july 2006
    Carterville,IL
    http://www.sta-ritepool.com/pdf/S260EN(6-3-03).pdf
    Maybe going to this site and going to page 6 will help you check your laterals. It helped me understand. Now my only ? is ....how to do it during the swimming season..or is it not possible?
    Installed july 2006
    All you have to do is turn off your shutoff valves (this would be one of the many reasons to have installed shutoff valves), and your pump and filter will be completely isolated from the pool, allowing you to perform a complete teardown of the equipment if need be. If you did not install shutoff valves, you can try blocking the skimmer hole and return with rags, but you WILL lose some water this way because it will wick through slowly.
    Lehigh Valley, PA
    What about fastening the skimmer plate over it? That would block out most of the water. And you can put an expandable rubber plug in the return to close it off.
    Anna
    Oval 12.5K gal AGP; Hayward 19" sand filter; Pentair Dyn 1 HP 2sp pump on timer
    [URL="http://www.ellerbach.com/Pool/"]My Pool Pages[/URL]
  1. BLowing sand out during backwash?
    By greenwich3 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-08-2012, 09:41 AM
  2. There is sand at the bottom of my above ground pool that keeps coming back.
    By confusedpool in forum Pool Equipment & Operations
    Last Post: 06-16-2012, 02:02 PM
  3. DE blowing back into inground pool
    By markginger in forum Pool Equipment & Operations
    Last Post: 04-15-2012, 04:51 PM
  4. Pump Blowing Filter Sand In Pool???
    By webfeet in forum Pool Equipment & Operations
    Last Post: 03-27-2007, 12:18 PM
  5. Sand blowing through returns
    By TR in forum Pool Equipment & Operations
    Last Post: 05-30-2006, 11:19 AM
