Results 1 to 10 of 15
Thread: For those of you with sand blowing back into the pool....
    ScottS is offline Registered+ Thread Analyst ScottS 0
    Covington, LA.
    Default Re: For those of you with sand blowing back into the pool....
    Great post, thanks!
    This will be another thing that I can check as well when I break the filter down.
    Now when you refer to the "hub" is that the point where all of the laterals screw into the PVC which connects to the multiport valve (this part rests on the bottom of the tank)? If so where was the space created?
    Sorry if the questions sound silly but I am trying to picture exactly where the tension was and what happened.
    Thanks Janet!
    Yes, it's the part that the laterals screw into, that sits on the bottom...when the laterals are seated in place, there shouldn't be any space between the laterals and the part they're connected to. (Sorry that may not be the best description, but I didn't think to take pics while we had it apart.) Mine were seated in as far as they would go, but it appeared as if they were not screwed all the way in, creating about 1/2" of space between the end of the lateral and the hub, on three of the laterals. Further, The hub has an opening underneath it where the filtered water goes back up into the center into a pipe, and that pipe connects to an L-shaped piece of pipe that goes back out to the multiport valve. It is the connectioin between this L-shaped pipe and the hub pipe that the sand got in between and literally sanded down the inside pipe at the joint, creating space between the two pipes for more sand to enter the return stream.
    Does that help?
    Quote Originally Posted by chuck9997 View Post
    I have the same problem.. with sand.. in a 24foot AG.. I am clueless about tearing down the filter.. and what to look for inside. Are there any pics and/or instructions for filter repairs and maintenance. Is it a BIG job?
    It's really not a big job....we opened the drain plug at the bottom to let the water drain, bled off the air while slowly removing the nut on top and taking the top off....then it's just a matter of scooping sand out of the filter. It would take much less time with a wet/dry vac, but it took me about 45 minutes to shovel 300 lbs of sand into the bucket of my tractor and go dump it. When you get to the bottom and can see the laterals, the whole assembly lifts out. Not a big deal, just kind of messy.
    Tennessee.
    I've been thinking about this.. and,.. at least for the first time,.. I think I will do as Andy Taylor told Aunt Bee.. I'll: "CALL THE MAN" .. and watch him.
    Swimming pool.. or camper? Swimming pool.. or camper? ...what the heck.. buy both.
    Carterville,IL
    This is my first FULL season with the new 30' AG. I am seeing some sand along the seams quite often.Vacuumed yest. and wa la...today....more sand. Probably only a 1/2 a cup full. Not much, but annoying. A friend of mine told me not to back wash as often, as it makes the sand "more sticky". This didn't sound too intelligent, AND I don't back wash every single week. My pool doesn't have many people in it often, and at that not many kids. I backwash about once every 3 weeks. I know I know....but it's looked good since day 1.
    Anyway, I don't assume I have a cracked lateral, and probably have a lateral head with some "space". The filter was already assembled when they installed, so I guess I have to wait till I close the pool in order to "check this". Sounds like a good plan, but I guess I can deal with the sand till mid sept when we close.......
    I just can't imagine how to do all that with the pool still open? Plus, I would rather try and wait and just kill two birds w/ one stone and change the sand next season. I know that with Chlorine, they say every 3-5 years, but whats $30 or so to ensure sparkling water w/ fresh sand eh?
    Anyway.....keep this post going. Very educational....and with all my jibberish, can someone post me back?
    30' Esther Williams Classic Granite
    Installed july 2006
    Carterville,IL
    An idea would be for someone to go to say the website of a filter, screen shoot the diagram of the lateral heads, and describe based on what the diagram shows. Just a thought.
    Installed july 2006
    Jul 2014
    Madison, WI
    New versus old laterals. Slightly different models, as I have an older Triton from the 80's as opposed to the current Triton II.
    26,000 gal IG vinyl liner pool (20'x40'), Waterway SMF-110 wet end w/ Century SQS-1072R motor, Pac-Fab Triton TR60 sand filter, K-2006A. Manually added chems: 12.5% NaClO liquid, granular CYA, baking soda, 31% muriatic acid.
    Jul 2014
    Madison, WI
    I suppose this could have happened before I was putting the laterals in, but I think I overtightened the laterals, and... CRACK! There goes the hub...
