It's really not a big job....we opened the drain plug at the bottom to let the water drain, bled off the air while slowly removing the nut on top and taking the top off....then it's just a matter of scooping sand out of the filter. It would take much less time with a wet/dry vac, but it took me about 45 minutes to shovel 300 lbs of sand into the bucket of my tractor and go dump it. When you get to the bottom and can see the laterals, the whole assembly lifts out. Not a big deal, just kind of messy.
