Thread: Is it a stain, or my lying eyes?
    mbar's Avatar
    Ashland, PA
    Default Re: Is it a stain, or my lying eyes?
    No, your eyes are not playing tricks on you - it probably is a mineral stain. You can take some vitamin C tablets and crush them up in a sock, or ph down, and rub it on the stain - if it takes it up it is a mineral stain. You can take your ph down to 7 - 7.2 and put in some metal remover (sequestering agent) and it should lift the stain. Let us know if this takes care of the problem. I have a fiberglass pool, and if it has stains you mostly see them in the pool when there is no sun on them.
    Northeast PA
    steveinaz is offline Lifetime Member Weir Watcher steveinaz 2 stars steveinaz 2 stars
    Southern Arizona
    What makes testing the stain difficult, is if the lighting changes, the stain disappears. I'll give it a shot though.
    mbar's Avatar
    Ashland, PA
    If it is that hard to spot, then I would ignore it
    Northeast PA
