Thread: SWG and filter timers
    Default SWG and filter timers
    I am getting an AQUARITE HAYWARD GOLDLINE AQUA RITE SALT POOL SYSTEM. It is being delivered next week. The question I have is can I still use the timers for my pool filter. As I read in another post, the cycle for the SWG is about 100 mins. Should I set each cycle of my timer for 120mins to allow the SWG to work properly or do I need to run it longer or all the time?
    16 x 32 IG concrete kidney; ~76,000 litres
    Hayward: Super Pump M/N C48k2N143B1; Pro Series Filter M/N SP714TC; 4.2 chlorine feeder; 6 2'x20' sungrabber solar panels with separate pump
    Default Re: SWG and filter timers
    Oh Yeah!!
    How much salt will I need to add at first?
    Welcome to the forum-you're in the right place! My owners manual gave approximate amounts of salt to add for various size pools. First, though, you need to get salt test strips (about $10) so you can determine how much salt is already in the water. One source is the sweaty people who jump in that cool pool. My manual recommended 800# for my pool but it only took 540# to bring it up to proper salinity. Guess we have a lot of sweaty friends! Good luck!
    Hal
    Scottsdale, Arizona
    My SWCG is tied right into my timer for my pump. It runs about 8 hours a day right now. 9pm to 1am and then again 4am to 8am.
    Test your current salt level and post it. There is a calc tool floating around here that someone will post that can calculate the amount to add .. Also, how much salt and CYA does your system mfg recommend?
