Re: ph low
Sal soda will raise both pH and TA. It does not matter if you broadast it or put it in one place. You are thinking about the 'slug method; of lowering TA, which has been proven NOT to work. All slugging acid does is ruin the pool because of the pockets of very low pH created.
Baking soda will raise TA and cause a slight rise in pH compared to sal soda
Borax will raise ph with minimal impact on TA.
As far as your pH meter, are you calibrating it on a regular basis and storing it with the electodes wet? pH meters are only accurate if they are regularly calibrated against standard solutions and if the electrode is properly cared for. The ONLY kind of pH meter I would trust is one that uses a 3 point calibration (calibrated against 3 different pH standard solutions.)
