Page 3 of 3 FirstFirst 1 2 3
Results 21 to 24 of 24
Thread: Disappearing CYA
  1. #21
    Default Re: Disappearing CYA
    I understand the concept of breakpoint chlorination, I could swear that I read a post by Ben a few years ago that he didn't beieve in the process of breakpoint chlorination, he made mention of CC will be broken down by sunlight - I guess I'm mistaken.
    The K-2005 kit has an increment at 0.5 PPM and I can see that. I did check for CC when my chlorine was 0 and had none. I stopped checking my CC based on the above info. I do throw in 2x the normal chlorine at times to kill anything that hasn't been killed. I should have checked that my CYA was still there and probably should have shocked the heck out of the pool in the beginning of the season.
    It definately is a learning experience.
  2. #22
    The comparator in the K-2005 is calibrated at .5, 1, 1.5, 2, 3, and 5 so while it can determine .5 CC at lower chlorine levels it's precision is only 1 or 2 ppm at the levels most likely encounted in pools with normal CYA levels (3.5 ppm FC and 30-50 ppm CYA). Dilutions will further decrease the precision of the test. This is why FAS-DPD testing is better. The precision is either .5 ppm or .2 ppm (depending on sample size) no matter what the FC level is.
    I wonder if this is the thread you are referring to when Ben said he wished people would not test CC? I think the point he was trying to make was that people worry too much about small amounts of CC spikes when they should be worrying about general water maintenance. UV will destroy these small amounts of CC but if there is a large amount caused by some chlorine demand then high chlorine levels are needed.
    Here and Here are artricles by the PPOA about superchlorination which basically say the same thing Ben said in the thread above and have some veryi interesting info.
  3. #23
    That probably is the post and I understand that small amounts need not be burned off with chlorine but I would also think that adding 6 PPM FC to a pool with 0.5 PPM CC will burn it off assuming that the CYA is at a low level.
    As I said I never test for CC in the pool, only my spa but I guess in a situation like what I'm going through it might be worthwhile to test. But ...
    ... now more questions come to mind - Can CC really start accumilating if you are running high FC (8 - 10 PPM or more)? I would think not as anything under 1/10 of the chlorine you put in would be burned off (I am assuming that the pool started at 0 PPM CC and CYA is under 50). My pool was at 0 CC when I noticed I had no CYA.
    How long do you need to keep a high chlorine environment? If you put in 10 PPM FC at 6 PM and you test at 6AM and have 6 PPM left, hasn't the chlorine done it's job. I always thought that as long as you have a FC residue that there isn't any more that the chlorine needs to do. (again CYA under 50). And wasn't the high chlorine in the tub burning off the CC as it was forming?
    In my mind, a "shock" really isn't a specific quantity - it can be as low as 5 PPM FC or as high as 20 PPM FC, which is why I questioned the 15 FC figure for shock.
    At this point with my pool not seeing a FC under 5 PPM since I started this post I would assume that any algea is dead. I actually put in 146 oz of bleach into my pool last night which yeilded 7 PPM chlorine added to what was there I was hovering around 11 to 13 PPM. I "shocked" the pool for the last time although I doubt there was a lot of CC in there.
  4. #24
    CC can accumulate, it depends on how much ammonia and urea or other organics are in the water. If you are killing algae then 0 ppm CC is a good indicator (along with the Fc holding overnight) that you have killed all the algae. If you do not raise the FC high enough to destroy all the orgainics in the water you will still have CC left.
    Your example of putting in 10 ppm FC at 6 pm and losing 4 ppm overnight indicates that the chlorine is fighting something in the water and you need to continue to shock until the FC holds overnight when UV degredation of chlorine is taken out of the equation. This is a basic of the BBB method on here. Just read the posts!
    "Shock" is really raising the FC high enough for the level of CYA in the water to insure that there is enough 'active' chlorine to do the job and it is not bound up with the stabilizer in the form of chlorinated isocyanurates but is in the form of hypochorous acid.
    It is a combination of having no CC and having your FC levels hold that indicates that you do not have a chlorine demand in your pool. If this is not the case you need to continue shocking and possibly try shocking to a higher FC level. It is also important to keep the FC at shock level by adding more chlorine at least a few times a day.
  1. where is my CYA disappearing to?
    By dalejanus in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-24-2011, 03:33 PM
  2. Chlorine keeps disappearing
    By mpetrov in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-18-2011, 11:26 PM
  3. Disappearing chlorine...
    By nthach in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-30-2010, 07:35 AM
  4. Chlorine Disappearing
    By newbie2pools in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-02-2009, 10:04 PM
  5. disappearing free chlorine
    By woman.n.a.shoe in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-08-2007, 05:27 PM
