Thread: PolyQuat??
    Pacific Northwest
    Question PolyQuat??
    I live in Canada and I haven't been able to find a Polyquat product called hth.
    I understand that it is a liquid algicide and that it is recommended as a product to help prevent algicide from forming in your pool.
    This product contains:
    60%
    poly oxyethylene (dimethyliminio) ethylene (dimethyliminio) ethylene dichloride according to Ben's page:
    http://www.poolsolutions.com/gd/polyquat.html
    There are a number of liquid algicide for sale in my area. I have been able to find these products... would you recommend one over the other.
    Bioguard's Algae ERASE
    3.3% Elemental Copper with polcarboxylate and polyhydroxy acid stabilizers
    OR
    Poolcare SUPER Algae Kill 40%
    This has the same elements as the polyquat Ben recommends but only at 40% strength.
    Which product would be better to use, and at 40% is it strong enought to do the job.
    Thanks for any help you can provide.
    Dave
    Lehigh Valley, PA
    Default Re: PolyQuat??
    Hi Dave,
    The product I use is called Poly60 and is made by Seaboard. I don't think there's a polyquat called hth. HTH is a manufacturer.
    Since you can't find Poly60 I'd use the 40 but more of it.
    Anna
    Northern Kentucky
    Don't use a copper-based algeacide, as you will be asking for more troubles!
    Like Anna said, the 40 would be your best bet.
    Are you having a problem that makes you think you need the polyquat? or are you planning ahead for closing your pool for winter?
    ~Grace
    Avid reader of this forum
    but alas, no pool... yet!
    Lehigh Valley, PA
    Quote Originally Posted by GraceByDesign View Post
    GRRRRR! Don't we have a rule that says you can't use the w-word until after the end of September?????
    Michigan
    Quote Originally Posted by AnnaK View Post
    Anna
    I never heard any mention of a true poly that was less than 60%. Experts please help?
    Why BBB? Because money can't buy happiness, but saving it sure can!
    Quote Originally Posted by doggie View Post
    Yeah, it's out there--usually 30%. It LOOKS cheaper but when you do the math it's more expensive.
    Lehigh Valley, PA
    Here's a link (of many similar ones) to a less than 60% poly:
    http://www.focuspools.com/products/S...ENTRATE-30.asp
    Anna
