polyquat question
I bought some polyquat earlier this year. I use the BBB method exclusively and have great success. I run my CYA around 70-80 as I use less FC daily.
My question is I would like to use the polyquat as a second defense.
Here are my postings
FC 11
TC 11
PH 7.2-7.4
ALK 90
CYA 70-80
How much poly should I use? And what intervals should I use? I see sign of algae every once in a while when there is low use( no one stirring up the pool) or we go away for a few days. Brushing takes care of that but,,
How much should I use for 22,000 gallon IG vinyl pool and how much will it drop my FC so and how long does it take to drop the FC
Thanks in advance...Mike
- You may not post replies
- You may not edit your posts
Forum Rules
