Results 1 to 3 of 3
Thread: Dirt in Pool
    cinbia12 Guest
    Default Dirt in Pool
    For the past several weeks we have what appears to be yellow dirt and some black flecks on the bottom of the pool. We have a DE filter and the pool is about 9000 gallons. At first we thought it had somethin to do with the pucks, because it would be fine after vacuming and within a half hour it was on the bottom again, but it also happens if the filter isn;t running. It is very fine, it you hit it with the brush it goes up in a cloud. Could this be mustard algae. The black particles are very small and almost look like gnats or something.
    NY, USA.
    Unhappy Re: Dirt in Pool
    Quote Originally Posted by cinbia12 View Post
    Did you ever get a response?? I seem to have the same problem with my DE Filter & would interested to know what others think it might be.
    Default Re: Dirt in Pool
    My first thought is that it may be pollen--do you have trees nearby the pool? Or construction going on in your area? If so, vacuuming or daily brushing to stir the stuff up in the water and let the filter take it out is about all you can do.
    It's also possible that it's mustard algae--what is your CYA level, and what is your average chlorine level? Does the yellow powder form on the sides of the pool or just the bottom? And does it appear to increase in amount over a few days?
