Results 1 to 10 of 11
Thread: Adding Bleach Method
    Wisconsin
    Default Re: Adding Bleach Method
    Thanks Al.
    topless is offline Registered+ Thread Analyst topless 0
    Jul 2006
    Wichita, KS
    I stopped adding to the skimmer after discovering what it was doing to the pump seal.
    I had to change out my pump motor this summer. The motor had a 12 month warranty and it had only been in 9 months. When I installed the motor last year I had installed a new seal. I checked the seal while I had it apart and the rubber was hardened and showing signs of cracking.
    At the time the motor went out, I was shocking my pool a high levels just after opening. Since I didn't have but a month last year and 2 weeks this year running the pump, I'm convinced it was the high chlorine level that was getting to the seal.
  1. adding bleach
    By kev6262 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-11-2012, 06:17 PM
  2. How often should I be adding bleach?
    By Charles in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-27-2011, 01:45 PM
  3. Adding Bleach w/CYA in skimmer?
    By JJParrish in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-07-2007, 04:46 PM
  4. Adding bleach to the skimmer
    By trauh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-21-2006, 03:07 PM
  5. Question on Adding Bleach
    By jrv331 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-19-2006, 10:41 AM
