algae help
Inground vinyl pool. 28k gallons. 5 years old. Water clear, algae growing in some areas on liner/ladder/lights. Alkalinity and ph about normal. Salt system. CYA reads zero and free chlorine .5ppm. Inside of salt cell and pipe jets has rusty or black looking coating. Some rust stains on skimmers also. Is salt cell bad? Do I just need to add CYA? Already have had SWG on super chlorinate for 30 days and still only reading .5 ppm chlorine. Salt level at 3200ppm.
Thanks for any suggestion you may have.
- You may not post replies
- You may not edit your posts
Forum Rules
