Solar Cover Whoes
In the past 2 weeks we have gone through two solar covers. I noticed one day our old one had lost all the air pockets in the bubbles [looked like a blue piece of bubble wrap that someone had popped] at the time I figured it was from high chlorine or low PH, so I bought another, waited until the chlorine lowered, made sure the PH was ok, cut it to size & toss it on the pool [its just a small 8ft diametre pool]
A day later I noticed the same thing had happened to the new cover, it had completely lost all the air pockets and was barely floating on the water surface.
I've since tapes together bits to form a 3rd blanket, it too is starting to lose its air pockets. My Chlorine & PH seem normal, pool temp is 27-29 celcius, its been very sunny lately.
I never had this problem last year, I am totally perplexed at what is causing it
Any help, suggests, or wild stabbing guesses are more than welcome
TIA,
Heather
- You may not post replies
- You may not edit your posts
Forum Rules
