Results 1 to 10 of 21
Thread: Muriatic acid distribution methods
    North Florida
    Question Muriatic acid distribution methods
    I saw something on another pool site (NOT known for its water balancing advice) that adding MA in a single stream in the deep end would lower pH and alkalinity but that dribbling it around the pool would only lower pH and not have much of an effect on alkalinity.
    This didn't sound right to me, but thought I'd put it out here to get the water-balancing experts' opinions. If somehow it IS true, well, then I'll definitely be changing my distribution method!
    Sandy
    Scottsdale, Arizona
    Default Re: Muriatic acid distribution methods
    I broadcast mine while walking around the edge of the pool but I did hear a guy at the pool store explaining to a customer how to add it in 4 areas of the pool only. I'm not sure if he was trying to drive down his Alk or not .. I'll let the experts here inform us on the validity of this method.
    I'm curious as well.
    Michigan
    I was told that adding it around the perimeter of the pool would lower PH more than if you added it to one single spot in the deep end.
    Why BBB? Because money can't buy happiness, but saving it sure can!
    Indiana.
    All are bad ways to add it and all are wrong with regards to the effect it has on the TA and pH. Muriatic acid lowers both pH and alkalinty regardless of how you add it. It is much heavier than water and sinks straight to the bottom and stays there unless you run the filter when adding it. Even then, you should take precautions to make sure it gets mixed in with plenty of water by either adding it very slowly in front of a return or mixing it with water before adding it to the pool.
    Ontario.
    Quote Originally Posted by JohnT View Post
    I had added the crystal/powder form and realized a couple of minutes later that my pump was off... never seen me move so fast.... I brushed the bottom to be sure it was well stirred too.
    IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
    Heating? Great info on why a solar cover saves $$$?
    http://energy.gov/energysaver/articl...ng-pool-covers
    Guelph, ON, Canada.
    I believe the Taylor Test Kit user manuals refer to a 'slug' method of adding acid which is supposed to affect TA more than pH. However this has been debunked elsewhere on the site.
    Carl Schnurr
    96,000 litre inground, vinyl liner, 1 HP 1speed pump, sand filter, SWG, installed 2005.
    salinda is offline Lifetime Member Weir Watcher salinda 0
    San Jose, CA
    I put mine in a single stream in front of the deep end return with the pump on. I add acid on a regular basis and I watch the plume to make sure it is hitting the return jet and mixing in. For me, that is a little to the side of the jet....
    Salinda
    Here is the thread that talks about the 'slug method' and here is a link to the paper that debunks it!
  1. Where to get 31.45% muriatic acid?
    By laughingboy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2010, 12:31 PM
  2. Lowering TA with Dry Acid Or Muriatic Acid
    By CelticDaddio in forum Dealing with Alkalinity and Calcium
    Last Post: 07-05-2007, 01:54 AM
  3. Where to buy Muriatic Acid
    By CelticDaddio in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-25-2007, 05:39 PM
  4. How to add muriatic acid
    By BullDean in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-12-2006, 11:51 PM
  5. how much muriatic acid
    By wolfcue in forum Dealing with Alkalinity and Calcium
    Last Post: 06-07-2006, 06:55 PM
