3 Possums and a Squirrel later
Well been awhile since I posted. anyways I took cover off pool and found 3 possums and a squirrel at the bottom basically like a soupy mess. anyways I scooped em out what I could put 2 bags of shock in. I had keep the pump running for 2 weeks with a puck in it every few days. Anyways after I shocked it I added 3 pucks over the weekend after I had vacummed out the mess. And dropped some more pucks in Monday night. Tuesday we swam and I noticed a green cloud forming that night. So I shocked it again with 6 gallons of bleach and 2 pucks. CYA is at 60 FC is 13 ALK is 130 PH is 7.2 . Pool is 10,000 gallons Do you think anything the critters left in the the pool is dead now? Hell I just figured shock the pool and a few pucks later and any stuff leftover from animals is dead? IS IT SAFE TO ENTER THE WATER?
Reason: Left out info
Re: 3 Possums and a Squirrel later
As long as you're shocking it to the proper levels (FC 20 ppm with a CYA of 60), then the water is safe to enter. See my post in the thread below...
http://www.poolforum.com/pf2/showthread.php?t=8475
