Thread: What PPM Sodium for non SWG pools when adding salt?
    mjs31 is offline Registered+ Thread Analyst mjs31 0
    Texas
    Default What PPM Sodium for non SWG pools when adding salt?
    I know this is a preference item, but has anyone come up with an approximate number for this? I am at 1800ppm but it just does not feel like it is high enough. Not getting the good hair and skin feeling like I have before and my eyes get red as hell. I just don't know if I would go to high by adding more or not.
    By the way....I have a 24' round 54" deep Artesian and would be adding and 99.9 (or whatever) salt bags.
    steveinaz is offline Lifetime Member Weir Watcher steveinaz 2 stars steveinaz 2 stars
    Southern Arizona
    Default Re: What PPM Sodium for non SWG pools when adding salt?
    You probably need to be at 2500ppm or better to really feel the difference. Use a good salt test, like Taylor to verify.
    aussie is offline ** No working email address ** aussie 0
    Quote Originally Posted by mjs31 View Post
    G'day MJS31,
    We started this mess 30 odd years ago in Australia,
    EVERYBODY HAS A SALT POOL OVERSEAS, THIS IS NOT NEW TECHNOLOGY
    we recommend 6000ppm salt, your body is 8000ppm, the ocean 36000ppm, our competitors cannot handle that amount of salt content,
    calculate at 40 pounds of salt per 1000 gallons of pool water
    and I will not debate this on this forum
    TRY IT, YOU WILL LOVE IT.
    Ric Varley
    WATERMAID -USA., INC
    WE ARE A MANUFACTURER
    Ft Lauderdale, Fl
    The salt feel is subjective. You're safe to add a bag at a time, until you get the feel you want. Make sure your calcium hardness level is not too high though. This can counteract the feel of the salinity in the water.
    Keep in mind that the red eyes are not only as a result of adding salt to your pool. I can be caused by having combined chlorine, improper pH levels, or improper water balance.
    (not to debate - AutoPilot operates at 3000 ppm, and can operate at 6000, 8000, or 35,000 ppm. However, be cautious with your high chlorine levels and salinity levels when you have stainless Steel components in contact with the water).
    Sean Assam
  1. New Member Question: Is the salt from bleach or sodium hypochlorite harmful?
    By dmeyer in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-17-2013, 11:55 PM
  2. Frequency for adding Sodium Dichlor ?
    By CJDahl in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-08-2006, 04:58 AM
  3. adding cya to pools
    By cleland418 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-19-2006, 03:16 PM
  4. Adding sodium bicarbonate AND calcium chloride at the same time
    By thr56 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-23-2006, 03:03 AM
