All you need is plain solar salt that is used in water softeners. It is 99.5% pure. You can also use the pellets but they take much longer to dissolve. It's usally 99.8% pure. Just make sure it has no additives for iron removal or anything added to clean the softener. It should be much less expensive than pool salt, which is usually just solar salt that is gound up finer.
