Re: Running pump at night?
I'm on the same type plan as mentioned above and have a salt system as well. I run 9PM - 12:30PM and the again from 5AM - 9AM. with good results. If I did not have the salt system and need the time to generate chlorine I would run a couple hours less since I'm currently turning over the pool a lot more than necessary.
