Re: Chemicals are good, so why are my eyes irritated?
Update:
Eye irritation is greatly reduced after adding 260 pounds of salt and five pounds of Cyanuric acid. I also fixed the high TA using the gas law technique.
Using the Taylor K-2006 I now get these results:
FC - 3
CC - 0
PH - 7.6
TA - 90
Ca - 240
Cya - 30
Using the Taylor K-1766 Drop Test for Chloride:
Salt - 2200 ppm
23,000 gallon In Ground Plaster Pool
2.5 Hp two speed Hayward pump
48 Sq. Ft. D.E. Filter
Thanks go to Richard (Chem Geek) and CarlD for your valuable guidance.
Phil
