Help!!! Removing Multiport Valve
Bit of history. Bought the house (from a co-worker) 4 yrs ago. Inground 24,000 gal concrete pool built (as far as we know) around 1986-88. Think the Tagelus TA-60 sand filter w/ multiport valve is original. Have done everything maintainence-wise myself (self-taught thanks to sites like this!). All markings on filter are illegible. Have original "manual". Not much help.
Sand needs to be changed. I know the previous owners changed it about 5-7 yrs ago. At the time they changed it, I worked with the wife (not speaking to her now). The did it themselves so I know it can be done. I remember her saying what a pain it was to get their hands inside to pull out the old sand so they had to have taken at least part of the valve off. I'm not sure if I have to take off the entire valve to get to the sand inside the filter. I unscrewed the 6 screws on top & took off that part & the only thing I found was the spider gasket (intact) and I can see partially into the valve itself (no sand visible). Tried to move parts inside...nothing. I disconnected all 3 hoses from the bottom portion so I could remove it but cannot get the entire valve off the top of the filter. I'm not sure if it's just supposed to "lift" off or screw off. There is no other spot to disassemble so I assume that I have to take the entire thing off. Won't budge. Sprayed lubricant on it and figured no matter what, the safest thing would be to try to twist it. Afraid of the pipe shifting and breaking the laterals.
Am I wrong in assuming the valve even will come off the filter....if not, how would you replace a faulty valve w/o also replacing the filter.
Any advice???? HELP!!!!!
