Thread: cyanuric acid
    Smile cyanuric acid
    my reading is up to 132 with all other readings being in the suggested range ,the pool girl said highest possible is 150
    she also says my big tabs are causing it to go up
    I had to drain down at the begining of the year becasue t was to high after winter now i just want to make it through to September
    is the a way to keep it from going up ?
    Default Re: cyanuric acid
    Yes. Quit using the tabs and just use bleach for your source of chlorine. Post a full set of numbers and somebody here can advise you better. BTW - the pool girl is wrong about 150 being the highest that the cya can go. And, unfortunately, the only way to lower the cya level is to do a partial drain. With yours as high as it is, it would take several partial drains to get it to a more manageable level. You don't want to totally drain a pool at once, however. You may not want to drain now, but you'll certainly need to in the spring upon opening if you opt not to do it now.
    heres the numbers
    copper =o
    iron-o
    ph= 7.4
    cya =132
    total hardness=263
    total chlorine .9
    total free chlorine .7
    I did supershock-it as they suggested so the reading now will have a chlorine
    Indiana.
    Quote Originally Posted by kickurasin View Post
    heres the numbers
    copper =o
    iron-o
    ph= 7.4
    cya =132
    total hardness=263
    total chlorine .9
    And when you shocked it, you added more CYA or calcium. You have to stop using dichlor and trichor if you want to keep the CYA down.
    Red face Re: cyanuric acid
    I know hunh, i think we establised that ,now that i know the tabs are the problem(for sure) i will yank them out when i get home
    then we(I) can learn how to do it with the liquid bleach .
