Hi
Back after a year or two away - everything was good but not so good now.
I have an in-ground vinyl pool apx. 14,000 gallons in volume.
I test the water myself but also take a sample in to the local pool store when I run in to some problems. I am in that situation right now.
My tests indicate my pool vitals are all good... however, I am struggling with some persistent lime green water.
Yesterday's Store Test Readings
TDS: 400
Stabilizer: 20
FC: 1.5
pH: 7.5
T.A: 95
C.H: 160
The store prescribed I increase the TA (which I did with Baking Soda), decrease pH (I didn't), add stabilizer (which I did), Shock with 2 bags of Burn-Out (which I did) then add 1/2 quart liquid algicide (which I did).
After following that prescription the pool looks exactly the same, lime green water. Back to the pool store for a new reading:
Today's Test Readings
TDS: 600
Stabilizer: 30
FC: 5
pH: 7.8
T.A: 135
C.H: 160
So today the pool store said 2 bags Shock again, and another 1/2 quart of liquid algicide.
I said forget that... I'm going back to bleach.
After reading and refamiliarizing myself much of what these forums say... I have added sufficient bleach to get my chemistry up to 15 ppm - I hope (as my test kit doesn't show anything beyond 3ppm). I used what seems to be a very good online pool calculator (http://www.poolcalculator.com/) to calculate how much bleach I needed to add.
I have thoroughly brush my pool and intent on adding more bleach as needed (although it is kinda tricky to figure out my FC beyond my test kit - I actually bought some quick test strips that show if my FC is around 10 so hopefully that will help).
I figure I will continue to monitor throughout the day and evening... add bleach when I think it might be due and continue to brush periodically as I see algae settle.
Does all of this sound REASONABLE?
I appreciate any feedback you can provide.
Thanks in advance.
Dave
