I'm not sure of the math of bleach vs pucks, but I do know that cal-hypo pucks are also adding calcium to your water. The only way to get rid of excess calcium is to do a partial drain and refill. Everything you put in your pool adds something, but the olnly thing bleach adds is sodium - which is good for the eyes! It is also almost ph neutral. Once you get your cya in a range, it is very easy to figure out your own pool chlorine demands. You will be able to adjust easily for excess bather loads. It is easier to pour 1/2 bottle of bleach in when you need a little extraI know that you are a bleach fan, but tell your wife not only is it cheaper, but you can use it for other things around the house too, so it will never go to waste
