It sounds like the bond wire isn't connected well to the ladder or coping. If the bond wire was connected to everything, it would take an enormous current to see 8 volts between any two parts of the pool. Do you have a concrete deck? What was the other point he was using to measure voltage? You may want to call your utility company to check their connections in your area. They are probably familiar with stray voltage.
