Results 1 to 10 of 12
Thread: Pump turnover rate
    waldreps is offline Registered+ Thread Analyst waldreps 0
    Lake Park, MN, USA.
    Default Re: Pump turnover rate
    I have an AO Smith 1.0HP pump with an SF of 1.40. I don't know how to calculate all the suction and return head stuff, so I just used the rough estimate of multiplying 2.31 x 17psi (from the gauge on my filter after backwashing) = 39.27. According to the pump chart that would be 65gpm but my filter is only rated at 52 so I used 52gpm. My pool is about 30,000 gallons and that comes out to be 9.6 hours for one turnover. So, two would be 19.2 hours which is pretty close to 24/7. Did I do something wrong? I was trying to determine if I should install a timer and not run the pump 24/7, but for 5 hours I'm not going to worry with it.
    mas985's Avatar
    Pleasanton, CA
    You also need to add the vacuum head which for your case may be around 10 ft. So your total head is about 50' which is normal for a pool. Also, even though the filter is rated at 52 gpm, it does not mean it limits the flow only that damage may occur after 52 gpm, so your flow can still be higher.
    Mark
    Ft Lauderdale, Fl
    Its common for pool contractors to size the equipment accordingly. The pump is sized to provide enough circulation to filter the whole pool once every 8 hours. Then once this is determined, the filter is sized to accomodate the flow rate.
    DE filters can handle twice the flow rate that the filter is rated for (65 sq ft filter can handle 130 gpm). Cartridge filters are equivalent (100 sq ft filter can handle 100 gpm). Sand Filters are usually rated for 15 gpm per sq ft of filter area (7 sq ft sand filter can handle 95 gpm).
    The horsepower x service factor is your true motor horsepower output.
    Your 1 hp pump x 1.4 sf = 1.4 HP (use the pump curve for 1.5 hp)
    Hope this helps.
    Sean Assam
    Question:
    My filter PSI is ~12, so that's ~28' for return head. I don't have a vacuum
    gauge, so I'll just use 10' for suction head. Do I need to add anything else
    for the 3 scuppers and 1 gusher I have, or is that accounted for in the 12 PSI?
    Thanks!
    Ft Lauderdale, Fl
    Nah,
    That's all you'll need.
    Sean Assam
