Re: Baking soda turned my pool green
Pool manet is a sequestering agent. It sounds like you got copper in your water somewhere - I hope not from your heater coils
Your pool has been very acidic, which would keep the copper in suspension. You then added all the baking soda, which caused the copper to precipitate into the water. High ph, alkalinity, calcium added to chlorine could precipitate metals out of suspension. You can add the sequestering agent - you don't have to wait for the chlorine to drop down. You are probably just on the brink of the metals precipitating out, and the sequestering agent will keep them in suspension. All I would do is add the sequestering agent, the chlorine will use some of the sequestering agent up, that's why they want your chlorine down, but not fast enough to do harm - I would think letting your chlorine down will be worse, giving you more of a chance to get algae again. So, add sequestering agent - wait about two hours, then add borax - it will be hard to get the ph up, because the sequestering agent will take your ph down, and use up chlorine- so you will have to test often, taking the ph back up (only to 7.2 for now), and adding bleach to take it back up to 5 each time you test. Your water should clear with your pump running 24/7. You can add the sparkle up - it is just cellulose to coat the top of the filter to filter out small particles - so it will help clear the water. I never heard of anything that really gets metal out once it is in the water, so I don't know if I believe that sparkle up will do it
As long as there is enough sequestering agent in the water, your water will not test possitive for metals. You will have to add sequestering agent any time you see the metals start to precipitate out into the water(not a big deal). I think your water will be blue and clear in no time
Your alkalinity is fine where it is. Keep us informed
Northeast PA
16'x32' kidney 16K gal IG fiberglass pool; Bleach; Hayward 200lb sand filter; Hayward pump; 24hrs; Pf200; well; summer: none; winter: mesh; ; PF:7.5
