Hi Sandy,
Could you describe a little more about the algae? You mentioned stringy things on the bottom. Was the pool water yellow with stringy things? or the stringy things on the bottom yellow?
Do you have any pictures from above the water? or close-up?
did you vacuum with a skimmer sock? do you still have that to show what the substance looks like?
What type of filter do you have? if it's a cartridge filter could you snap a few pictures before you clean it?
Thanks so much!
dan
