Results 1 to 10 of 21
Thread: Cooling a Hot Pool
    Default Re: Cooling a Hot Pool
    well you could always pump some water out and refill, I'm sure the tap water is cooler than the pool.
    Quote Originally Posted by cleancloths View Post
    It would work, but in some areas (I believe Dallas is one), they have water restrictions that would make draining/refilling a problem. Also, depending on your fill water composition, draining and refilling can really mess with your chemical balance.
    And, with the high temps that much of the country is having, it would only be a matter of days until the water temp was back up there again. So, it could be a short lived fix.
    Well, there's full proof that Ben is totally AWOL - Duraleigh's post wouldn't have lasted more than 5 seconds and Duraleigh would now be permanently banned from Poolforum even though he has given years of insightful and extremely helpful advice to many a lost soul on this forum.
    One thing that keeps coming to my mind about using a fountain is loss of water to evaporation - bearable if you have a water source to replenish from, not so bearable when you have to pay to truck your water in.
    Burrying the hose would definitely help, however, in climates with frost (where hot water problems would likely be less prominent), it may cause an issue when it comes to draining the hose at year's end.
    DFW Texas
    Quote Originally Posted by matt4x4 View Post
    Wouldn't it also drive up PH levels?
    IG concrete, 16K gallon, DE, BBB, Polaris 360
    Actually, aerating will lower your pH, but yes, it will have some effect on your water - however, raising your pH is easier than lowering it - simply add borax.
    Mandeville, LA, USA.
    Aerating will raise pH but without raising alkalinity (much). So the end result, after adding acid to lower your pH again, will be lower alkalinity.
    Jul 2006
    We've had clouds and cooler temps the last couple of days. So not much solar heat getting to the pool. When it was sunny I checked the temps it went from 92 to 89. Not much cooler. I will check the ph and alk this weekend to see if it is changing. I did run across a comercial mister device I'll see if I can find it again and post a link. It seems to be very similer to the device posted, but prebuilt. It was about 29.00 and hooked up to an eyeball socket. Compared to the forced air fan type at 2600.00 I think it may be worth a try. I have notice some more rapid water loss, not much but just about 10% more than normal for this time of year. Thanks for the input.
    Rick
    Caledon, Ontario, Canada.
    Contrary to Matt's suggestion of running the pump at night to mix the water I would suggest that maybe the opposite would work.
    If the water is more or less stagnant, the hottest water will rise to the top. You can ofter feel this when you swim in stagnant water. Colder at the bottom.
    So if you want to lose heat, maybe you should let it rise to the surface and cause more evaporation for cooling. Everyone I know says the greatest loss of heat when you're trying to get a pool warmer, is off the surface.
