Thread: CYA Testing
    Sumo1 is offline Registered+ Weir Watcher Sumo1 0
    Default CYA Testing
    I have a Taylor K-2006 test kit with the CYA test that instructs to stop adding reagent when the black dot disappears. For me that seems to be a very inexact measurement and I can get varying test results from one test to the next. I'm not sure the time to stop is when the dot first seems to be gone or keep adding reagent until the dot's absolutely obliterated! Does anyone else find this test confusing or have any tips or ideas that might help? TIA
    Hal
    20x40 IG gunite free form, approx. 27K gal, 60sq DE filter, Jandy Stealth 2hp 2speed pump, Polaris 380, SWCG
    duraleigh Guest
    Default Re: CYA Testing
    The test is imprecise by it's nature. You should add solution until the black dot disappears completely.
    To get repeatable results, it is helpful to always perform the test in the same lighting conditions. This usually means indoors in the same spot. Results will still vary a little but it should get you close enough for the test to be meaningful.
    Honesdale PA
    I use fluorescent desk lamp light reflected off a white card and look down through the tube with the light coming up from the bottom. The results closely match the recommended method of using direct sun and viewing at waist level. I think that's the recommended way. And yes, the measurement is a judgement call and I let the dot completely disappear.
    California
    For what it's worth, this link at the Taylor website has pictures of the CYA test (scroll down) that give an idea of how the black dot disappears.
    giroup01 is offline Registered+ Thread Analyst giroup01 0
    Canada
    Or [DEAD="http://cjoint.com/data/ivbMMzZhAC.htm"]this[/DEAD] blast from the past!
    Reseller of Taylor water-testing products for Canada
    Thank you for your responses!
    Hal
  1. Cya testing
    By RedwingT in forum Pool Chemistry for Intex-type Pools
    Last Post: 09-14-2012, 08:00 AM
  2. testing, testing, 123
    By poolowner in forum General Interest
    Last Post: 06-07-2011, 01:21 PM
  3. Testing CYA
    By laughingboy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-07-2010, 10:34 PM
  4. CYA testing
    By KirstenHW in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-22-2006, 09:28 PM
  5. Testing for CYA
    By psteward in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-28-2006, 11:22 AM
