Those are all forms of chlorine. We really need to know your cya reading. Those tabs are continually adding more and more cya and when you get too much, it can be a problem. Most of us here on the forum just use plain, unscented laundry bleach as our source of chlorine. What ingredients are in the shock powder and in the granular chlorine? I have a feeling one or both of them may be dichlor powder. It, too, will add more cya. Post as soon as you get that cya reading for us to look at.
I have, for reasons beyond the scope of this particular question, used trichlor tabs in the autochlorinator for the past 8 weeks - nearly the entire season. My values have remained steady: FC=3, CC=0, pH=7.5, CYA~30-40. The pool is in full sun, there's a daily swimmer load of 3 dogs and 1 human for ~ 1.5 hours. We've had a lot of rain and I do have to top the water off a couple times a week; these factors may have contributed to the CYA level not rising in any appreciable way.
I've never had a CC reading and have not applied a shock treatment other than at startup and closing each season.
Anna
Around here, we don't think a cya level of 80 is fine, but you can compensate for it by just keeping your chlorine level high. (We actually recommend cya of 30-50.) But, at any rate, with a cya level of 80, you need to keep your chlorine level between 5-10 all the time, and whenever you need to shock it, you need to take it up to 20. While you are trying to clear the pool, test the water at least 2-3 times a day as Janet suggested above, and each time, add enough bleach to take the chlorine level back up to 20ppm. The key to killing algae is to sustain a high cl reading. If you let it yo-yo up and down, you will never get the water clear. In a 25,000 gallon pool, each 3 quart jug of 6% bleach will add just under 2 ppm of chlorine to your water. Also, run the pump 24/7 while you are working to clear it.
At this time, don't add anything else. The pool stores will tell you that you need a bunch of different products, but you don't. Just bleach. Take a look at the 2 stickied threads at the top of the algae forum. Those pics should convince you that bleach is all you need.
Keep us posted about how it is going. Any more questions -- ask away. Somebody around here will try and answer. Good luck.
Hi Hubjeep,
I feel your pain! Last year (our first w/a pool) was a nightmare! BUT, Janetcleaned it up in NO TIME! We were very fortunate to find this site and the mods here were/are wonderful. They are patient and knowledgable and, together, I believe they can do anything with a pool! I don't think I read that anyone suggest you actually lower your CYA to the 30 to 50 range, but, they did kinda' mention it. That could be a big help to you?
You would need less bleach, and to me, that is important dollar wise. I still consider myselef a newbie, but I just wanted you to know that you are in good hands. If you follow their instructions, your pool will be crystal clear in no time! Good luck, Joyce
.....btw, our pool still looks wonderful!
18,000 IG Gunite/Plaster, Hayward Sand Filter
Thank you, JJParish, for the kind words! Glad your pool is not giving you problems this year, and it's good to see you back!!
Thanks for the help everybody! It took less than two days to clear up after I used plain bleach. By day three it was crystal clear.
Before:
