Thread: Water Behind Liner
    jrv331 is offline Registered+ Thread Analyst jrv331 0
    Default Water Behind Liner
    I saw a posting earlier, naturally cant find it now, about running water behind the liner to remove wrinkles. Just exactly how does that work? How is the water supposed to get out from behind the liner if its tight against the pool wall. Gonna try to pull some wrinkles out this week before closing.
    John
    Default Re: Water Behind Liner
    John,
    on an IG pool, usually, people float (run water behind) their liner to get it to lift enough to re-seat the bead into the receiver when it pulls out - once the water drains, the liner will push back in place on the wall and floor.
    your pool is not sealed behind the liner and he water will naturally drain itself (gravity) out.
  1. Water under liner please help
    By mkaman1 in forum In-Ground Pool Construction and Repair
    Last Post: 06-13-2011, 04:54 PM
  2. New liner, new water!
    By Gretchen in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-12-2011, 05:51 PM
  3. Wrinkled Liner and Water Behind Liner
    By rbposey in forum In-Ground Pool Construction and Repair
    Last Post: 09-26-2009, 05:40 PM
  4. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 09:04 PM
  5. Water Behind Liner
    By kdnulph in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-25-2006, 11:46 PM
