Thread: Pump is off...will pool get green?
    Default Re: Pump is off...will pool get green?
    Quote Originally Posted by Henrys514 View Post
    How long does it take for the pool to get green when you can't run the pump? ...
    My pump is having some problems (VERY long story, but I can tell you who NOT to use for repairs if you live in Louisiana), and has been disabled since last Thursday. I had chlorine in it as of Thursday afternoon at 12 ppm, with a CYA of 80. So far, it's not changing colors. Hopefully will have the pump back within the next day or two, and a good overnight shocking should clear up anything that started to grow. So....if you're adding chlorine and stirring with a paddle (or broomstick, or whatever), you're probably okay for several days.
    Central FL
    No, we're in Florida. That really sucks about your pump. I feel your pain. My husband managed to patch most of the leaks somewhat, so they are now dripping rather than gushing. We're running the pump for about 4 hours a day until Saturday when he rips everything out and starts again. At least I don't have to use a paddle now
    My pump is back in business now, and water is still clear blue, so I know you can go at least 5 days, as long as your chlorine stays within the right ranges given your CYA level. Hope your husband is able to get it fixed without too much of a headache!!
