Results 1 to 8 of 8
Thread: So what do you do?
    Default Re: So what do you do?
    Quote Originally Posted by kickurasin View Post
    why does everyone want numbers
    my strips only show colors???
    Everyone wants numbers because they can tell us a lot about what's causing the "cloudy fizzy water". There are many reasons for water to not be clear, but there's no way for us to advise you on what's causing your problem without knowing the condition of your pool, and we need numbers to do that. To try to diagnose problems without levels for CYA, FC, CC, pH, TA, and sometimes CH is just shooting in the dark--wild guesses, which don't do you any good.
    Test strips are known to be not accurate enough to help manage water problems. They can be used to get "ballpark" figures, but to get accurate numbers to fix problems, you need to use drop-based reagent testing.
    It is possible to use the pucks without draining and refilling a lot of water, but you need to have a good handle on your pool chemistry in order to do so.
    well from reading here it seems the cya will always continue to build up
    but here they are
    cya 85
    ph 7.5
    akalinity 100
    hardiness 237
    free chlorine 1.9
    total chlorine 2.8
    but here they are
    cya 85
    ph 7.5
    akalinity 100
    hardiness 237
    free chlorine 1.9
    total chlorine 2.8
    The CYA will always build up, but does reduce some by splashout, backwashes, and dilution. The key is to either stop using them altogether when your CYA is where you want it, or use them at a very low feed rate (starting with a low CYA) but with bleach to maintain your desired chlorine amount.
    I find that I can use the tabs throughout a summer swim season, then switch to bleach or cal-hypo over the winter, and the CYA goes back to almost nothing over the winter due to backwashes and rain dilution. Of course, I run a higher CYA level than most people due to my location and the sun exposure of my pool, but you could still use the tabs with the feeder turned very low and just supplement with bleach. Or switch to cal-hypo or bleach for regular chlorination and just use the trichlor tabs in a feeder for vacations, etc. They are useful, if you know what you're doing. But if you try to use them exclusively for all your chlorination, yes, you're going to find yourself in the high CYA/drain/refill cycle.
    With your CC at .9, you definitely need to shock the pool and maintain that until the CC goes away. Keep the pump running and brush your pool daily. With a CYA of 85, you need to make sure that your TC never drops below 5, and really is better maintained around 6-7. When you shock, you need to shock up to 20 in order to do any good. Don't use dichlor for this--it's only going to raise your CYA higher. Use cal-hypo, or better yet, plain bleach.
    so keeping a level at 6 is what a gallon a day of bleach for a 10000 gallon pool ?
    mbar's Avatar
    Ashland, PA
    You can't just use a blanket statement, like 1 gal of bleach per day per 10,000 gallons. I gal of 6% bleach will raise chorine 6ppms in a 10,000 gallon pool. What you use will all depend on your bather load, cya and sunlight on pool. You can go back and read all of the stickys - and some old posts, they are a wealth of information. Untill you post your true numbers, we can't give you specific details.
    Northeast PA
