Thread: Oops!!
    Default Oops!!
    I've switched to running my pumps at night trying to reduce water temp (to little or no avail). The other day after we swam I put the Polaris back into the water and set the switch to run when the timer kicked it on. Problem is, I forgot to open the water valve! OOPS!! I discovered my mistake the next morning after it had been on about 7 hours. The pump was still running but was nice and hot. When I opened the ball valve, the water fittings at the pump all started leaking so I shut the pump off and closed the water line. Haven't had time yet but am sure I'll have to refit the water line to the pump. How will I know if I've damaged the pump internally? Any thoughts or suggestions? TIA
    Hal
    Honesdale PA
    Default Re: Oops!!
    If nothing leaks and there are no abnormal noises then you're probably OK. The motor itself would not be damaged by running dry.
