Re: SWCG and winter months
So Sean, just to make sure I understand, with the AutoPilot I don't have to shut it off for winter? The unit will do that on its own? Or would it be better to shut it down to prolong the cell life?
One other thing, is it normal to see large swings in output with small changes in water temperature? For example, I set mine to 50% when the water was 81-82 degrees, then when it cooled to 78 the setting went down to 38%. I was getting some algae so I turned it back to 50% and as you'd expect, the setting was up around 70% when it heated back up. Is there a way to adjust this (that is, the unit's sensitivity)?
Thanks!
about 27,000 gal IG w/spa
Polaris cleaner
Autopilot SWCG
Pentair cartridge filter
