Results 1 to 10 of 10
Thread: Motor replacement -- Most reliable website for online ordering?
    Bay Area, CA
    Default Re: Motor replacement -- Most reliable website for online ordering?
    I am looking for AO Smith 2hp motor, #K48M2PA104 (Looks like the replacement part # is USQ1202).
    When searching for #USQ1202, lots of websites come up and so do a lot of the price variances.
    Brian
    South Bay Area, CA
    West, Texas
    I just recently had to replace my motor and I bought my new one from poolcenter.com and I was very satisfied with the results.
    Boyd
    27' Round AG, 17,204 gallons, sand filter
    Proud Father of an Army Soldier
    Bay Area, CA
    I had my dad come by and pick the motor up. We're going to try a local shop for the bearing R&R.
    Brian
    South Bay Area, CA
    Honesdale PA
    If it is just the bearings it is an easy and cheap fix provided you can press or knock the old ones out. When pumps are exposed to the elements, i.e. wet, the bearings can really get rusted in so that you can't get the old ones out without destroying something. Tried freeing the bearings on a pump last year that was exposed to the elements for a number of years. Used every trick I know and no luck. Rest of the motor was pretty weatherbeaten too. My pump has resided in a poolhouse for 9 years and looks like new. More reasons to keep rain and snow off a pump.
    Good Luck.
    Bay Area, CA
    Looks like we're better off going with a whole new pump/motor assembly. My pool originally came with a 2hp motor, but since then we've added solar heating.
    Would jumping up to 2.5hp be any sort of major issue? It looks like I'll be moving more water, which is a good thing, because sometimes we have 10-12 people in the pool at one time. I need that turnover!
    In the meantime, I bought a 1/4hp submersible pump to keep the water moving from the deep end into the hot tub. I'm not letting my pool turn green!
    Brian
    South Bay Area, CA
    Poughquag, New York, USA.
    More than likely you can get by with LESS pump, rather than more. Most pool builders oversize pumps. What you need to know is how many suction side inlets do you have and how big are the pipes, how many returns do you have and how big are the pipes. Also, unless your solar is on a 2nd story, you really don't need to upsize the pump for solar. Poolplaza.com has good pump info, I have not bought from them, but the website is really informative.
    Living in CA, you should look at getting a 2 speed or multi-speed pump. If they aren't already required, they are going to be soon. You should be able to get a significant kickback from your electric company for installing an approved pump (call them before buying anything).
    Bay Area, CA
    Decided to just order a new replacement motor, impeller, shaft seal, and pump housing seal.
    Also, this is a good opportunity to move my DE filter to the other cement pad we have. It'll give me more room around the pump/motor area, and around the filter for future servicing.
    Lastly, while the water evaps from the pool I think I want to get the tiled calcium build up off. Can anyone recommend products for doing so?
    Brian
    South Bay Area, CA
