Results 1 to 10 of 10
Thread: Motor replacement -- Most reliable website for online ordering?
    Honesdale PA
    Default Re: Motor replacement -- Most reliable website for online ordering?
    If it is just the bearings it is an easy and cheap fix provided you can press or knock the old ones out. When pumps are exposed to the elements, i.e. wet, the bearings can really get rusted in so that you can't get the old ones out without destroying something. Tried freeing the bearings on a pump last year that was exposed to the elements for a number of years. Used every trick I know and no luck. Rest of the motor was pretty weatherbeaten too. My pump has resided in a poolhouse for 9 years and looks like new. More reasons to keep rain and snow off a pump.
    Good Luck.
    Bay Area, CA
    Looks like we're better off going with a whole new pump/motor assembly. My pool originally came with a 2hp motor, but since then we've added solar heating.
    Would jumping up to 2.5hp be any sort of major issue? It looks like I'll be moving more water, which is a good thing, because sometimes we have 10-12 people in the pool at one time. I need that turnover!
    In the meantime, I bought a 1/4hp submersible pump to keep the water moving from the deep end into the hot tub. I'm not letting my pool turn green!
    Brian
    South Bay Area, CA
    Poughquag, New York, USA.
    More than likely you can get by with LESS pump, rather than more. Most pool builders oversize pumps. What you need to know is how many suction side inlets do you have and how big are the pipes, how many returns do you have and how big are the pipes. Also, unless your solar is on a 2nd story, you really don't need to upsize the pump for solar. Poolplaza.com has good pump info, I have not bought from them, but the website is really informative.
    Living in CA, you should look at getting a 2 speed or multi-speed pump. If they aren't already required, they are going to be soon. You should be able to get a significant kickback from your electric company for installing an approved pump (call them before buying anything).
    Bay Area, CA
    Decided to just order a new replacement motor, impeller, shaft seal, and pump housing seal.
    Also, this is a good opportunity to move my DE filter to the other cement pad we have. It'll give me more room around the pump/motor area, and around the filter for future servicing.
    Lastly, while the water evaps from the pool I think I want to get the tiled calcium build up off. Can anyone recommend products for doing so?
    Brian
    South Bay Area, CA
    topless is offline Registered+ Thread Analyst topless 0
    Jul 2006
    Wichita, KS
    I went to Graingers, through my job, we have an account there.
    Most electric motor repair shops carry replacement motors and you may find their prices quite competitive, especially since you won't have to pay freight. The A.O. Smith motors come with a 1 year warranty.
