One thing to remember is that once the pump is primed, static head is no longer an issue. Only dynamic head will determine the flow. After prime, the 8 ft rise is balanced by an 8' drop on the other side of the pump.
If you have a 2 speed controller, then normally it sets the pump to run at full speed at start up and then after 3 min, it drops the speed to low speed.
