Results 1 to 4 of 4
Thread: SI calculator
    p.p.h. is offline ** No working email address ** p.p.h. 0
    Dec 2005
    Phoenix, AZ, usa.
    Default SI calculator
    Is there an online SI calculator?
    Katy, TX
    Default Re: SI calculator
    Yes.
    Michael
    SI can be useful...
    But don't live or die by it. If your other numbers are good, and your pool is clear, don't mess with stuff to improve the SI.
    But if you are having troubles, the SI may help you pinpoint what is wrong.
    Me, I keep it simple and stick to Ben's test kit...You'll rarely have a problem that it cannot identify--and 98% of the time that problem will be due to metals, bacquacil, or ammonia-based algaecides in the water.
    mas985's Avatar
    Pleasanton, CA
    I have my own spreadsheet for the calculation but here is a good online version: http://www.advancedh2o.com/technical.../langlier.html
    Some do not include TDS in the calculation which can create some error if you have a SWG. If I do not have a good TDS measurement, I estimate with CH + Salt level. This is pretty close.
    Mark
  1. Pool Calculator; useful?
    By JimK in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-09-2013, 10:22 PM
  2. The Pool Calculator
    By Scetnk in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-25-2011, 02:17 PM
  3. Borates calculator
    By Phillbo in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-02-2011, 11:44 PM
  4. Pool Calculator
    By pedsrn in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-17-2010, 07:49 PM
