Mike, sounds good to me, which is probably why your not needing/ receiving any input from the rest of us
If you have a solid cover, sun can't 'activate' any algae when the cl drops -- if you have a mesh cover, you might want to pop a corner back every week or so until the water is too cold to support algae growth and check cl and cc, once the water is 50-55deg, you won't need to do this until the water warms back up.
How 'BOUT them 'Eers!!![]()
